Highest draw on 12V outlet?
Old Jan 29, 2006 | 10:45 PM
matt65's Avatar
What is the highest amperage draw that can safely be applied to the 12V outlets in my 1997 Z28?
Old Jan 30, 2006 | 06:11 AM
matt65's Avatar
Re: Highest draw on 12V outlet?
I have a maximum of 17 A compressor that I am wanting to hook up to fill 6 gallons of air tank.
Old Jan 30, 2006 | 07:09 AM
smoknta's Avatar
If you are talkng about the cigarette lighter plug, I would not draw that much from it. On the 93's the fuse feed is a 25 amp, but it feeds the cigarette lighter and horns. The wiring feeding the cigarette lighter is 18AWG, and 17 amp would be pushing it. I would suggest hooking right up to the battery.
Old Jan 30, 2006 | 09:51 AM
matt65's Avatar
Thanks. I have been tring to figure out what the sustained amperage is. It specs a max, but image that is only briefly during startup.
Old Jan 30, 2006 | 12:24 PM
Dave '97 Z28 M6's Avatar
Owner's manual says 15A max. for the cig lighter, and 3A max. for the accessory plug.
Old Jan 30, 2006 | 01:22 PM
T56LS102's Avatar
What is it that your trying to run???
Old Jan 30, 2006 | 04:32 PM
matt65's Avatar
Will be powering a Viair Air Compressor. Picture and specs below.
350C STANDARD FEATURES:
*Oil less design
*Hi-performance PTFE Piston Ring
*Gear-less Direct Drive Motor
*Moisture & Dust Resistant
*Anodized Aluminum Alloy Cylinder
*Automatic Reset Thermal Overload Protector
*Mounting Plates with Vibration Isolators
*Stainless steel braided leader hose
*Remote mountable inlet filter
*Inline check valve
350C SPECIFICATIONS:
*Voltage: 12 Volt/24VOLT
*MAX Amp: 17 Amps
*MAX Working Pressure: 150 PSI
*MAX Restart Pressure: 200 PSI
*MAX Duty Cycle @ 100 PSI: 100%
*Dimension: 9.0"LX4.0"WX7.05"H
Old Jan 30, 2006 | 05:36 PM
smoknta's Avatar
Will it be permanetly mounted in the car? If so I would run a deticated feed.
Old Jan 30, 2006 | 05:50 PM
matt65's Avatar
Since it is borderline on the Amperage I think I may use a distribution block on my amp power wire. I wont be running both the amp and the compressor at the same time.
I know some of you are wondering why I am needing a compressor. See image below (mine are similar model, but not as nice paint): Not for permanant mounting.
Related Thread: http://web.camaross.com/forums/showthread.php?t=417303
Old Jan 30, 2006 | 08:15 PM
98 SNAKE EATER's Avatar
You'll want to wire the compressor independantly using at least 14-16G wire
Your best bet is to use a ViAir combination pressure switch/power relay to run the compressor safely and reliably...
Rick
Aztek T/A WS7 & 70 RAM AIR IV T/A
Moderator @ LS2, FAST LS1, FUELSLUT,
The F-Body Hideout, LS1Turd & ChopperForums
G-BODYT56
Jan 14, 2022 11:14 PM
Quickss96
Jan 29, 2016 05:56 PM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
RX Speed Works
Jul 24, 2015 02:25 PM
