Emergency Please Help Me!!!!!!!!!!!
Old Jan 29, 2006 | 11:08 AM
LarrieuY2KSS's Avatar
Exclamation Emergency Please Help Me!!!!!!!!!!!
I was in the process of taking off my cat off the stock manifolds and broke the last freaking bolt on the drive side!!!!! I have everything off to put on a new Y-pipe. How dangerous is it to not have that one bolt? I plan on getting it fixed ASAP, but just need to know what if any problems will arrise? PLEASE HURRY!!!
Old Jan 29, 2006 | 11:13 AM
Greed4Speed's Avatar
Re: Emergency Please Help Me!!!!!!!!!!!
You'll probably have a nice exhaust leak. Only possible damamge is asphyxiation.
Old Jan 29, 2006 | 11:21 AM
what if any damage could there be to the engine?
Old Jan 29, 2006 | 11:38 AM
where is the freaking help in here!!!!!!!!!!!!!!!!!!!!!
Old Jan 29, 2006 | 11:46 AM
Need4Camaro's Avatar
It probably won't do anything to your Engine other than adding a slight whistling tone and changing your Exhaust Note a bit until you fix it...
Old Jan 29, 2006 | 01:01 PM
slowpoke96z28's Avatar
there shouldnt be any engine damage. if an exhaust pulse causes frsh air to be sucked in pass an O2 sensor, it will run a little rich, but not enough to wash out rings or anything.
Old Jan 30, 2006 | 07:16 AM
Kraest's Avatar
Retired
You're going to have an exhaust leak that's going to sound like **** and drive you crazy.
Old Jan 30, 2006 | 08:39 AM
TransAmAbe's Avatar
You're not going to damage your engine. You could damage your rear O2 sensor with the cold air entering the exhaust stream, but if you're taking off your cats I'm going to assume you're not really concerned about that. Your rear O2's just monitor how well your cats are working. An exhaust leak that far downstream is not going to burn a valve or anything. If the bolts you were removing and busted were the head/manifold bolts you got problems. But if it's just the bolt holding the cat onto the manifold, welcome to the club. Exhaust work sucks.
Abe
Old Jan 30, 2006 | 09:52 AM
Grims's Avatar
hah, calm down man. It's just an exhaust leak.
Old Jan 30, 2006 | 10:19 AM
Should have READ my post.
"Only possible damage is asphyxiation." That meant just that.
Old Jan 31, 2006 | 09:55 PM
all is good now i salvaged a bolt off of the old y-pipe. similar to the one on the flange but longer and managed to save it for now. only real problem was drilling (the broken bolt) that son of a b**ch out!!!!!!! man it was an interesting job. thanks for all who replied
Old Feb 1, 2006 | 02:29 PM
Grims's Avatar
Thank god, I can get some sleep now
Old Feb 1, 2006 | 02:42 PM
Kraest's Avatar
Retired
You do realize that Futral Motorsports is about 45 minutes away from you, right?
95GRNZ
West South Central
Jan 10, 2004 08:31 PM
91TransAmGTA
3rd Gen / L98 Engine Tech
15
Sep 18, 2003 01:24 PM
