Can't get the staple all the way back into the A4 shifter
Old Jan 27, 2006 | 03:12 AM
Need4Camaro's Avatar
I'm using a hammer and I can only get it about 7/8 of the way in, but it's still showing and you can DEFINATELY feel it when you put your hand on the shifter. Do I need to pop it back out and do this over?
Old Jan 27, 2006 | 03:35 AM
94Z28WP's Avatar
Re: Can't get the staple all the way back into the A4 shifter
You should be able to press it in with your finger... If you pull up and remove the shift ****, you'll see the groove the "staple" slips into... It's just a matter of getting it lined up with that slot.
Old Jan 27, 2006 | 05:33 AM
TraceZ's Avatar
pull it out, flip it over and try again.
Old Jan 27, 2006 | 09:56 AM
Cool, I got it in, the opposing angles of it made it difficult at the start as it was too wide... I used some pliers and bent in inward just alittle and it popped in and stayed like a charm...
... Unfortunately in process of removing it I slightly scar'd my leather boot Any remedy for that or is this permanant?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
karpetcm
Feb 9, 2015 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
