my 94 4L60E
Old Jan 24, 2006 | 12:20 AM
Randy1994's Avatar
my 94 4L60E
i just rebuild my trans cause i thought i had a vibration it. i found the forward clutchs flat wore out, the wireing harness was so brittle it fell apart during disassemble. aside from those the rest look pretty good for 148,000 miles on it. during reassemble i went ahead and put the corvete servo in it. runs like a champ now. but still chasing the driveline vabration.
Old Jan 24, 2006 | 12:37 AM
Bersaglieri's Avatar
Re: my 94 4L60E
Good deal. Try an aluminum driveshaft yet? Do you have a poly tranny mount? Did you check to see if the exhaust is rubbing anything?
-Dustin-
Old Jan 25, 2006 | 01:01 AM
Randy1994's Avatar
Re: my 94 4L60E
just put all new mounts in (tranny,torsional),still have stock split drive shaft w/carrier bearing, i did just turn the drive shaft 180 degrees today and the vibrations seems to have gotten a little bit less, so i figure i may try putting in a new carrier bearing and new u-joints and see if that helps
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
