A bit confused
Old Jan 22, 2006 | 12:53 PM
KylerCavers's Avatar
A bit confused
I'm not very familiar with gears so I have a few questions. First, I just discoverd that my 93 z28 (Manual) has 3.23's. Now I wouldn't mind a bit more acceleration without the sacrifice of alot of gas mileage but what is a good ratio to upgrade to? Also, what are the two differences if the car came with 2.73s or 3.23s if they both run high 13's to mid 14's?
Old Jan 22, 2006 | 04:12 PM
MyShibbyZ28's Avatar
Re: A bit confused
3.42's or 4.10's are the usual upgrade. The bigger the gear the more torque the axle will see, but also the higher the rpm will run. 2.73's and 3.23's are close so the only difference would be the little bit of torque difference and maybe the 1mpg difference.
If you want a better take off go to 3.73's or something, since you are a 93 you have a steeper first gear and a .65 6th gear, instead of the rest that have .5 6th. 4.10 might be too steep for a 93.
Nayr
Mar 3, 2023 08:34 PM
Double aught
Oct 2, 2015 11:29 PM
cmsmith
Sep 14, 2015 09:25 PM
Cam's maro
Aug 11, 2015 07:45 AM
Boss002
Jul 9, 2015 03:33 PM
