Meth Injection?
Old Jan 22, 2006 | 07:44 AM
CamaroDraggerZ28's Avatar
Meth Injection?
Any 1 here running a meth injection set up? Just wondering cause i dont want nitrous.
Old Jan 24, 2006 | 11:26 AM
96ta(nick)'s Avatar
Re: Meth Injection?
Methanol injection is used to prevent detonation mainly in boosted applications. You won't really see a power gain from using meth injection by itself.
Old Jan 24, 2006 | 04:56 PM
Re: Meth Injection?
what about alcohol injection?
Old Jan 24, 2006 | 05:29 PM
96ta(nick)'s Avatar
Re: Meth Injection?
Same with the alcohol.
Old Jan 24, 2006 | 05:39 PM
Re: Meth Injection?
so what exactly does alcohol and meth injecton do?
Old Jan 24, 2006 | 06:26 PM
buzz12586's Avatar
Re: Meth Injection?
Reduces the chance of detonation on a boosted motor.
Old Jan 24, 2006 | 06:41 PM
Re: Meth Injection?
if you run it with lets say an intercooled procharger will it increase the intercoolers effects
Old Jan 25, 2006 | 09:55 PM
roguedriver's Avatar
Re: Meth Injection?
Think of meth injection as a liquid intercooler, and the biggest benefit is you won't end up on COPS using it!
Ken R.
Old Jan 26, 2006 | 02:52 PM
96ta(nick)'s Avatar
Re: Meth Injection?
Originally Posted by roguedriver
Think of meth injection as a liquid intercooler.
Ken R.
exactly
Old Jan 27, 2006 | 03:54 AM
ocshaman's Avatar
Re: Meth Injection?
With?
It works in a different way than the intercooler
On?
Yes, the Meth would draw heat out of the IC, and therefore increasing the ability of the IC to intercool
Old Jan 27, 2006 | 01:48 PM
1Quick88's Avatar
Re: Meth Injection?
All meth does really is cool down the intake temps..lower temps result in being able to run higher compression with out detonation on boosted applications. No real benifit if your running N/A.
Old Feb 1, 2006 | 07:50 AM
MetallicTrans96's Avatar
Re: Meth Injection?
"It works in a different way than the intercooler"
See thats what I was thinking but my friend is using alcohol injection on his turbo system...he says he is shooting at a certain rpm during boost and should see a 60 hp gain...
Old Feb 1, 2006 | 08:04 AM
andy katzelis's Avatar
Re: Meth Injection?
Alcohol has a high latent heat of evaporation, cools as it evaporates. It also has a high octane rating.
Alcohol is great for blown or turbo applications to cool the incomming air/fuel charge. The high octane rating also allows a higher compression ratio for more power.
If your friends car is computer controlled he is probably using it to control detonation so he can run more timing and more boost making more power.
If you simply put alcohol into an engine not specifically designed for it you would likely lose about 30% power. Now, maximize the engine for alcohol and you can make more power than with gasoline.
drt
Sep 27, 2015 04:39 PM
Henson071
Sep 18, 2015 04:01 PM
Slayer
Aug 17, 2015 03:55 PM
Henson071
Aug 4, 2015 09:32 AM
RX Speed Works
Jul 24, 2015 02:25 PM
