Vortech with Crank Trigger ???
Old Jan 17, 2006 | 04:00 PM
[JFS]'s Avatar
Has anyone done a Vortech and crank trigger setup? The engine and FAST setup now necessitates one and I'm looking for ideas on getting all to fit.
-j
Old Jan 17, 2006 | 04:09 PM
[JFS]'s Avatar
Re: Vortech with Crank Trigger ???
other ideas welcome as well....
Old Jan 17, 2006 | 04:47 PM
Z8'S's Avatar
Been there done that http://memimage.cardomain.net/member...450_7_full.jpg
Old Jan 17, 2006 | 06:52 PM
[JFS]'s Avatar
Originally Posted by Z8'S
Picture is worth 1000 words ... however, I might need 1001.
Which ballance are you running? Which cog pulley? How was the machining done on that?
Old Jan 17, 2006 | 07:05 PM
Z8'S's Avatar
It is a ATI superdampner with ASP cog crank pulley,I used a universal MSD crank trigger and did all of the machining myself. I am a toolmaker by trade so its easy(lol) I had to change some dimensions on all parts involved to make it work.Machined down the thickness of the hub on the cog pulley and recreate the counterbore,then I had to open up the cranktrigger wheel to locate on the dampner. Then make a locator bushing to line everything up correctly. Then I had to modify the trigger pickup to work with modified Vortech bracket.Simple
Old Jan 17, 2006 | 07:10 PM
markinkc69z's Avatar
A flywheel trigger might be easier to implement if its a stick car.
Old Jan 17, 2006 | 07:20 PM
[JFS]'s Avatar
This is on an auto car, th400.
Old Jan 17, 2006 | 07:22 PM
[JFS]'s Avatar
Do you have other photos? Any suggestions on a simpler setup?
Old Jan 17, 2006 | 07:23 PM
[JFS]'s Avatar
Old Jan 17, 2006 | 08:15 PM
Z8'S's Avatar
You can modify your intake manifold to accept a distributor and get an Accel dual sync distributor.
Old Jan 17, 2006 | 08:21 PM
[JFS]'s Avatar
Interesting but not an option, other pics would be appreciated!
-j
Old Jan 17, 2006 | 08:24 PM
Z8'S's Avatar
Why is it not an option?I ran a dist. for 3 years. Not much on it but......http://www.cardomain.com/ride/827450/1
Old Jan 7, 2007 | 09:41 PM
Birdie2000's Avatar
Is the Super Mondo bypass just a Mondo, or is it actually different from what Vortech lists on their website as the Mondo Bypass?
Old Jan 7, 2007 | 09:55 PM
Z8'S's Avatar
The Super Mondo is different it flows about 2 times as much as the Mondo.I have pictures on my cardomain site but it is down right now
Old Jan 7, 2007 | 09:58 PM
Birdie2000's Avatar
nevermind, sending a PM
