T56 to th400 swappers---which trans cooler to go with?
Old Oct 31, 2002 | 09:01 AM
Nostang 96z's Avatar
Question T56 to th400 swappers---which trans cooler to go with?
I am in the process of swapping my t56 to a th400 and need to know which trans cooler to go with. I am going with a 4000-4200 stall 9" converter so I need something that can cool the trans for 80 mile trips or so. I have the m6 radiator so it will be an independent cooler that I go with. I was thinking about running 2 spearate trans coolers and mount them in front of my radiator but need suggestions. How do the coolers with their own fan work? I will be mounting it in front of the radiator no matter which cooler I go with. I have no A/C or bumper supports so It should be able to flow plenty of air to it. Which trans coolers did you guys go with? Any tips or suggestions?
Matt
Old Oct 31, 2002 | 09:08 PM
chevyguy3's Avatar
i went from a t56 to a th400 for this year. its really expensive, but i LOVE my Art Carr tranny cooler (the REAL art carr in california BTW). it cost $180, but it is really small and doesnt take up much radiator space which is nice since we dont have much space as it is. i have a 4200 stall converter, and just a stock capacity stamped steel pan, and my temps dont get over 125-130 on the street even beating on the car. at the track when i do back to back passes the tranny only gets up to 150. definitly worth the extra $$$
Old Nov 1, 2002 | 01:20 AM
I use a Perma Cool #12311, with 10" 10-blade fan. $132 from JEG's. It is mounted up inside the front fender, where some people put the filter for their CAI. Fine for street and strip.
TRANS COOLER
Old Nov 1, 2002 | 12:20 PM
Thanks for the replies guys, I appreciate the info. I think I'm going to go with the Perma cooler that Injuneer has. It seems to be compact and has ints own fan, plus it is a lot cheaper than the Art Carr cooler. Again thanks
Matt
RUENUF
Mar 13, 2016 03:39 PM
james007moore
Jan 1, 2016 01:14 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
