Weight diff. 12 bolt vs. 9" ?
Old Jan 4, 2006 | 01:09 AM
RedHottG2's Avatar
What is the weight diff. between the two ? I have been told the 12 bolt weighs less but by how much ?
Old Jan 4, 2006 | 12:49 PM
OBE1 95Z28's Avatar
Re: Weight diff. 12 bolt vs. 9" ?
http://web.camaross.com/forums/showt...ghlight=weight
Old Jan 4, 2006 | 12:54 PM
JakeRobb's Avatar
Super Moderator
From that thread:
12-bolt: 170lbs
9-inch: 217lbs
So 47 pounds heavier.
At what horsepower level, or 60' time, or whatever would be an appropriate measure, should one start to seriously consider the 9" for its added strength?
Old Jan 4, 2006 | 03:41 PM
89385formula's Avatar
My 9" weighs 190ish with an aluminum center section and steel spool.
Old Jan 4, 2006 | 03:42 PM
Capn Pete's Avatar
^ ^ ^ a spool weighs less than a functional diff though, right?
Old Jan 4, 2006 | 03:47 PM
Yeah, it does. My stuff may weigh a tad less than that. That is UPS scale weight, all 4 boxes added together. So it may be less. Ill let you know tomorrow. The aluminum center section weighs less that the nodular one by 15LBS, and I am not sure about the stock ford 9" setups. The 217lbs calculation was with a stock center section i believe.
Old Jan 5, 2006 | 01:09 PM
RedHottG2's Avatar
So one last question, what is the weight of a factory 10 bolt ?
Old Jan 5, 2006 | 04:16 PM
According to this thread, http://ls1tech.com/forums/showthread...ley+fab+weight, there is somebody in there that said that his 10 bolt full off fluid, and still totally complete with backing plates weighed 166.
I just got my stuff weighed out of the boxes and my 9" weighs 186lbs, but like I already stated it has a spool, aluminum center section, and the heavier 35 spline axles. It also does not yet have the backing plates put on either.
F550maranello2
Apr 1, 2015 11:10 AM
maybe2fast
Mar 16, 2015 09:45 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
