Shocks Question
Old Oct 30, 2002 | 12:44 AM
astrange22's Avatar
Shocks Question
I just order'ed a set of Eibach Sportline Springs and figured I would go ahead and replace the stock shocks becuase they would blow soon after lowering it.
So, Im woundering which ones to get. I've narrowed it down to the Bilsteins or KYB Adjustables. Ive seen two different kinds of Bilsteins, HD and SLP. What is the difference between them and does anyone know of good or bad things about the kyb?
Thanks for any input
Adam
Old Oct 30, 2002 | 01:30 AM
chuck's Avatar
The ND Bilsteins have more rebound than the SLP Bilstiens. I would suggest the HD Bilsteins.
Old Oct 30, 2002 | 05:05 AM
JackZ.Twenty8's Avatar
Yep, unless you can afford the double adjustable Konis.
Old Oct 30, 2002 | 03:53 PM
SunsetWS6's Avatar
Wink
If you're going with sportlines don't just get Bilstein HD, you won't be happy. Call Sam Strano, check out his # on LS1.com You'll need revalved Bilsteins or Konis to give you a good ride. Stay away from KYB. Also no need for D/A Koni, S/A Konis are what are practical.
Old Oct 30, 2002 | 06:23 PM
00blkz28's Avatar
if you havent already put you shocks in try the Qa suspention u can adjust them they are kinda salty but they are worth it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Apr 1, 2015 09:27 AM
dbrockma
Feb 16, 2015 02:56 PM
ModdedNerd
Feb 5, 2015 04:37 AM
