4l60e ?
Old Dec 27, 2005 | 07:40 AM
96birdlt1's Avatar
4l60e ?
Is a '94 4l60e a direct replacement for a '96. I had thought that the harnesses were different when they changed from OBDI to OBDII.
Thanks for the help,
Joe
Old Dec 27, 2005 | 08:17 AM
mike 96 ws6's Avatar
Re: 4l60e ?
94 is not PWM {pulse width modulation} like the 96 is. It's a whole different animal electronics wise. I don't know all the stuff that would need to be changed in order for it to work right. It may be as simple as a pump - valve body swap, but as I said, I don't know.
Good luck.
Old Dec 27, 2005 | 08:55 AM
1SlowFormula's Avatar
Re: 4l60e ?
too many differences to try unless you are willing to spend more on getting the 94 in there then just rebuilding the 96. you will need new electerinics, the electronic conectors are different between the years and you would need new connectors, and re-pin them, I believe there are slight differences in the tail housing but not sure what exactly.
Check these out..
http://web.camaross.com/forums/showthread.php?t=174516
http://web.camaross.com/forums/showthread.php?t=103033
http://web.camaross.com/forums/showthread.php?t=402436
http://web.camaross.com/forums/showthread.php?t=408191
http://web.camaross.com/forums/showthread.php?t=365542
just to name a few , search is your friend...
Old Dec 27, 2005 | 11:30 AM
96birdlt1's Avatar
Re: 4l60e ?
Thanks guys. That answers my question.
Joe
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
