Wiring question for any V6 owner.
Old Dec 20, 2005 | 10:53 PM
Bens3rdGen's Avatar
I have a 3.4L v6 I'm swapping into a chevy truck. It's from a 95 camaro, pretty sure it's a manual. I've managed to idnetify all the wires except for three connectors. Anyone with a v6 4th gen could probably identify these.
Here they are and thanks:
2-wire connector near driver's side exhaust manifold. It has a Green wire w/ wht stripe and another wire that is either brown or tan. It comes out of the harness at the exact place the o2 wire does, driver's side.
10-pin connector with 8 wires coming out of it. It's within 1.5 ft of the pcm. It comes out of the wiring harness at the smae place a 3 wire A/C connector does. I think the A/C connector is for the pressure relief sensor. Below is a list if the wires coming out of it
2 Large Pink wires
1 Small Pink wire
1 Large Green wire
1 Small green wire
1 Small Green wire w/ wht stripe
1 Small Brown wire?
1 Small Tan wire?
2-wire connector somewhere near the trans. Has a Large Light Green wire and a Large Brown wire. Shares the part of the harness that has the VSS. The connector itself is tan I think.
Any info you got is appreciated.
Old Dec 25, 2005 | 03:08 AM
Bens3rdGen's Avatar
Re: Wiring question for any V6 owner.
Anyone?
Old Dec 28, 2005 | 08:57 PM
Bens3rdGen's Avatar
C'mon, no one can pop the hood and look at a couple connectors. I can't find any v6 4th gens in my local junkyard.
How about this, if you own a v6 4th gen and you live within 30 miles of pasadena, let me know. I'll cruise over and figure it out for myself. I'll even bring a 6-pack or pizza which ever you prefer...thx.
Old Dec 28, 2005 | 10:19 PM
crasher88's Avatar
pics of the connectors and a pic of their general location and I'll probably be able to identify what they do for ya.
Old Jan 2, 2006 | 11:25 PM
mgbv6's Avatar
1. looks like fuel pump.
2. coils?
3.ac request
There re three connectors going to the PCM. Go on line or get a schematic from haynes or the real shop manual.
Old Jan 3, 2006 | 04:17 PM
Bens3rdGen's Avatar
Yea, I have the engine compartment wiring diagram and the PCM diagram. I figured out what all the other connectors were using these but these connectors don't seem to be on there for some reason or I'm just really missing something.
Trying to get pics up soon.
1. Does this go to the FP relay or directly to the fuel pump.
2. Makes sense I guess, never worked with coil packs before and they didn't come with the engine so I don't know what connections it requires. I buy the coil packs asap.
3. AC request huh, would explain the large guage wires. What is it doing by the trans? Does it go through the shifter hole, what does it connect to?
Thanks alot.
Ben K
Old Jan 4, 2006 | 12:13 AM
mgbv6's Avatar
Ben it goes to a relay directly and excites it. Also you are going to need a VATS bypass too, you can buy off of ebay about 30.00 bucks. The lt green,,,UMmm sorry about that, read it wrongly, the others are ok, I was looking at dark green. I wnt down and checked my 3.4 on the engine stand and it goes into the front connector on a T5 tranny. The longer one in the harness goes to vss. Anyway, the light yellowish green wire goes to the back up lite switch in the tranny. Should perfectly match up with the front connector on a T5. Thats why you have larger gauge wire, by the way, mine looks like it is 16 or 18 gauge.
Old Jan 5, 2006 | 12:18 PM
Bens3rdGen's Avatar
Just to make sure I got this straight...
1. Goes to the fuel pump realy
2. Goes to the coil pack
3. Goes to a T5 tranny for the back up lights.
BTW, I really appreciate your help. It would have taken me a very long time to get this info another way.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
lbrowne
Nov 13, 2011 04:25 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
