Shark nozzle in Trick Flow Elbow?
Old Dec 18, 2005 | 09:30 PM
Cmr0z28's Avatar
My 1LE elbow is starting to rip at the TB (this makes #2), so I'm looking to go a more durable route. Thinking about the Trick Flow elbow..... (is the ceramic one worth it, or is it just for looks?)
I was wondering how a Shark Nozzle would be mounted. Maybe Nitro Dave can help out...
Old Dec 18, 2005 | 09:53 PM
Z284thgen's Avatar
Re: Shark nozzle in Trick Flow Elbow?
mmmmmmmmmm i just got mine from summit ( the elbow ) and for this reason im gonna mount both TNT nozzel's in it..... but i didnt wanna cut the 1le up so i bought the metal one....
Old Dec 19, 2005 | 07:24 PM
Nitro Dave's Avatar
Actually you can just run a single nozzle in it. I know it has a divider but it will not matter.Beacuse at the throttle body you roll into one open intake plenum. I would juts take and drill and tap the elbow.
Dave
Old Dec 19, 2005 | 07:38 PM
89385formula's Avatar
Dave
There is no divider in the trick flow elbow.
Old Dec 19, 2005 | 09:20 PM
Nitro Dave's Avatar
Last time I installed one there was.
Dave
Old Dec 19, 2005 | 09:23 PM
AZ2ENVY's Avatar
ONLY vortech elbows have dividers in them . Trick flow does NOT have a divider in it .
Dave
I suppose i could be wrong, i know mine doesn't have one. Perhaps you are thinking of the Vortech elbows, I know they have the divider. Maybe someone else can shed some light on this?
Old Dec 19, 2005 | 09:25 PM
AZ2ENVY's Avatar
Look at my post above ^^^^^^^^
Old Dec 19, 2005 | 10:00 PM
Nitro Dave's Avatar
Ohh I got you.I subtract my statement then.I have only installed the vortec elbow.LOL
Thanks for straightning me out.
Dave
Old Dec 20, 2005 | 03:33 PM
Dave
Lol, no problem man. Just trying to help.
Old Dec 20, 2005 | 03:39 PM
Cmr0z28's Avatar
So um....drill+tap is my only option?
Old Dec 20, 2005 | 03:42 PM
Thats what I am doing.
Old Dec 20, 2005 | 04:15 PM
Bandit 1's Avatar
I have a Trick flow elbow I first mounted my nozzle in front of the throttle body by the IAT sensor, didn't like that so I moved it on the underside of the elbow right behind the MAF, alot better distribution in my mind. Drill and tap
Old Dec 21, 2005 | 07:27 PM
Mikes 1994 z28's Avatar
You might need to connect your lines to the nozzel using 90 degree hose ends. I encountered clearance problems with the stock hood im running. If you have a firebird or SS you might not have the same issues.
Old Dec 21, 2005 | 08:03 PM
95 TA The Beast's Avatar
I just talked to NX about this and they mentioned that adding a 90-degree fitting at the nozzle is the equivalent of adding 15ft of line as it is a major flow restriction at that point.
I am just wondering if I had a set of -3AN lines made up with 90-degree fittings if that wouldn't work better since there is no internal diameter change and it should be the proper geometry to aide in flow with causing a restriction?
