Cam swap questions, *1998* specific,
Old Dec 15, 2005 | 08:13 PM
StudyTime's Avatar
Okay, I'm about to order set of LS6 springs from sdpc, but I read the waterpump gaskets are not reusable like the rest of the seals on the GenIII motor for the '98s.
There is supposed to be an up-grade to the resealable waterpump gaskets.
Anyone have a p/n on this? What about the crankshaft pulley bolt?
I need info on those TWO items.
Thanks a lot,
Ben T.
Old Dec 15, 2005 | 08:14 PM
StudyTime's Avatar
Re: Cam swap questions, *1998* specific,
Originally Posted by PAGregSS
The new water pump gaskets are metal and are the same part number as for the 99s on up. I went into my files and pulled out these for you:
Water Pump Gaskets (need 2): 12559271
Crank Bolt: 12557840
It'd be a good idea to get a new crank seal for the timing cover also. Part # for that is 12585673.
What cam are you swapping to? If you need any more info, let me know. I've done two cam swaps on my '98 thus far.
Greg, I copied your original post. I felt this was very relevant information- exactly what I was looking for.
Old Dec 15, 2005 | 08:15 PM
StudyTime's Avatar
This is an MTI B1 camshaft. I've had it and my LS6 intake collecting dust for a long time, and they need to go in.
I plan to run this cam on a stockish program. Only minor changes have been made, my idle and rev-limiter were both raised, emissions deleted, etc.
We'll have to see how it works out. This isn't going in for probably 4 weeks or so though.
Ben T.
Old Dec 15, 2005 | 08:17 PM
StudyTime's Avatar
Ah, yes. You should be fine on a stock program for a while with that cam. My T1 ran pretty decent on my stock tune but with the combination of the cam and headers, it definitely needed tuned.
The LS6 springs should be fine but I'd keep an eye on the pushrods. With the bigger ramp on that cam over stock, you may bend them, even with the LS6 springs.
Reposted for you Greg. Thanks for your original.
Ben
Old Dec 15, 2005 | 08:26 PM
95Bird's Avatar
way to delete the other post
here is a thought..call thunder and order it.
Old Dec 15, 2005 | 08:55 PM
95Bird's Avatar
why argue with someone that doesn't listen to people that know more than he does.
You want part numbers..call thunder and order it. They will know the part numbers and may have them in stock..or are you looking for these used also.
Old Dec 15, 2005 | 09:00 PM
StudyTime's Avatar
Please keep your posts relevant.
Ben
Old Dec 15, 2005 | 09:36 PM
95Bird's Avatar
Ben T.
there ya go
Old Dec 15, 2005 | 10:35 PM
Cory1994z28's Avatar
I understand what you are saying. You might have only been trying to be helpful, but you come off as slightly confrontational. Your comments might have been relevant, but you should be careful with your word choice.... You sounded a bit jerkish..
Deadbolt24
Jan 19, 2015 01:29 PM
chuyz28
Jan 15, 2015 04:14 PM
hotrodyou1
Dec 20, 2014 10:05 PM
chuyz28
Nov 25, 2014 11:14 PM
