Window Electrical Diagnosis...
Old Dec 15, 2005 | 01:40 PM
scottso's Avatar
Passenger window has been flaky for a while - works, doesnt work, etc. (only from operation on driver side though). I just replaced the switch on the driver side - but it apparently was not the problem because it is still not working. So what is the best way to attack this? It works fine from the passenger side.
Old Dec 16, 2005 | 01:49 PM
Z28SORR's Avatar
Re: Window Electrical Diagnosis...
You've already done the diagnosis. It's not the drivers side switch, it's not the pass. side switch, it's not the motor, so what's left. Look at the connection and the wires. Get the wiring diagrams, if I recall correctly the current path goes through both switches then operating either switch.
Old Dec 16, 2005 | 04:03 PM
scottso's Avatar
I pulled the pass side switch connector and reseated it. Now it works. Odd, I guess the connector wasn't fully seated??? As to whether it will keep working....
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
z28cam1993
Sep 9, 2015 04:08 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
