Which engine is better, more powerful? The new GM 3.9 v6 or 3.6?
Old Dec 13, 2005 | 10:13 AM
BLUETOPTA's Avatar
Just as the question states. I see the new 2006 Impala has the 3.9 v6 rated at 240 HP. Its OHV and has VVT.
The Buick Lacrosse has the 3.6 v6 also rated at 240 HP. It is DOHC and has VVT.
Wich one is better?
Old Dec 13, 2005 | 10:20 AM
Aaron91RS's Avatar
Re: Which engine is better, more powerful? The new GM 3.9 v6 or 3.6?
The 3.9 seems to be a dog compared to what it should be with 40+HP from the reviews I read
In the G6's the 3.9 has 240HP and the 3.6 200HP.
I didn't know they made one with the same HP as the 3.9?
Old Dec 13, 2005 | 10:21 AM
GTPprix's Avatar
The last G6 GTP I tested ran a decent 14.7 without launching it too terribly hard and powershifting 1-2. Not too shabby for that car I think. As for which is actually more powerful, I've never seen the 3.6L in a performance application so who knows hehe
Old Dec 13, 2005 | 10:29 AM
Jason E's Avatar
Uhm, I'm not sure what reviews you've been reading Aaron, but the 3.9 has done well since its release. MT tested a pre-production GTP when it tested the '05 G6 GT, and said it felt a little slow. Since then however, the engine seems to be doing well. Edmunds liked it in the Impala, and MT liked it in the G6 GTP coupe they just tested...it ran a 14.5 IIRC, and did 0-60 in 6.2 seconds. When you consider I've seen LT1s test almost that slow, that's pretty good!
FWIW, when I drove a 6 speed GTP coupe and an AT GTP sedan, it felt good to me! Very quiet, too
Old Dec 13, 2005 | 10:47 AM
rlchv70's Avatar
Compare the torque curves:
http://media.gm.com/us/powertrain/en...7_LaCrosse.pdf
http://media.gm.com/us/powertrain/en..._Malibu_SS.pdf
The 3.6L torque is virtually flat across the rpm range. However, the 3.9L torque exceeds the 3.6 at almost all rpm points. Therefore, this is a strong argument that the 3.9L is faster than the 3.6.
Old Dec 13, 2005 | 11:03 AM
muckz's Avatar
You're thinking of the 3.5 200HP V6. We're talking about HF 3.6 DOHC engine.
Old Dec 13, 2005 | 11:07 AM
96_Camaro_B4C's Avatar
The 3.6 is at its weakest (for whatever reasons - exhaust routing? exclusivity for Caddy?) in the Buicks. In the CTS/STS/SRX, it is in the 255-260 hp range. And it will go higher (look at the Nissan/Infinity 3.5L, Toyota/Lexus 3.5L, and the new VW 3.6L VR6), though even as it is it is plenty strong for 99% of real world buyers.
No variant of the 3.6 makes only 200 hp. Aaron91RS, I think you are confusing the 3.6L DOHC V6 with the 3.5L OHV "high value" V6. The 3.5L is rated at 201 hp in the G6/Malibu/minivans, 211 hp in the Impala. The 3.9L is rated at 241 hp in the G6 GTP, Malibu SS, and Impala LT/LTZ. The 3.6L DOHC is rated at 240 hp in the Lacrosse and Rendezvous, but 255+ hp in Cadillacs.
Old Dec 13, 2005 | 11:17 AM
HAZ-Matt's Avatar
I am guessing you could get the 3.9 to perform a little better too.
Old Dec 13, 2005 | 11:39 AM
Aaron91RS's Avatar
ya oops. To many new engines all at once.
Not sure why either. Pick one with the best HP and fuel economy and technology and save some money by not producing so many varients.
Old Dec 13, 2005 | 11:55 AM
91_z28_4me's Avatar
Joe I can't belive you forgot the 210 hp 2.8 HF.
Seriously I think if people want to compare the two lineup a LaCrosse CXS and a Impala LTZ. That should be the closest comparison you can get.
Old Dec 13, 2005 | 12:08 PM
Gold_Rush's Avatar
3.6's tune seems rather mild. I think it has the potential for alot more than its making now.
As for which is the better motor...easy, the 3.6.
Old Dec 13, 2005 | 02:40 PM
I didn't forget, though I see how you took it because I referred to a "variant" of the 3.6 (probably should have said "application" instead of "variant" to be more clear). I was talking about the 3.6L displacement version of the HFV6, which gets a 240 hp rating at its lowest, in the Buick applications. I was making sure Aaron had it straight, because he had mentioned 200 hp in his post, but he was referring to the 3.5 and mistakenly thought 3.6.
But yes, there is a HFV6 family member that is close to 200 hp, and that is the 210 hp non-turbo 2.8L. Just not a 3.6L.
Old Dec 13, 2005 | 07:55 PM
305fan's Avatar
I drove a 2.8L HF in the CTS and thought it was great, if not powerful.
Very smooth, with exciting noises made all the way to redline.
Haven't driven a 3900 but M/T was raving about it--saying it feels like a OHC engine.
Reada roadtest of a 3.6L 6 speed CTS--14.9. Somethings not right. Maybe the 3.6L needs a rework. The FWD 240hp versions are too low!
G6 GTP--14.4
But the CTS is heavier but not by too much.
Old Dec 13, 2005 | 09:51 PM
HAZ-Matt's Avatar
No replacement...
I am voting 3.9L unless they decide to actually utilize DOHC and spin the 3.6L to 7000. When do we get the 3 valve 3.9?
The 3.9L got Popular Mechanics "Breakthrough Award" (whatever that may mean).
Old Dec 13, 2005 | 09:54 PM
CCoop8830's Avatar
Ahhhh all these V6s are better than mine. Urrrr.
