Direct Injection Compatible with Pushrods?
Old Dec 13, 2005 | 02:39 AM
teal98's Avatar
Does anyone know if a standard single camshaft pushrod engine is compatible with direct injection?
From what I've seen, the newer direct injection engines from VW and Toyota have very impressive power and fuel efficiency. I'm guessing that in a few years, it will be as common as variable valve timing is today, and a few years after that, as common as fuel injection is today (at least on gasoline-powered piston engines).
What I'm wondering is if this means the end of the LS engine architecture?
It seems to me that the main advantage of the extra camshaft(s) is that you can vary the valve timing between intake and exhaust more easily than with a single cam for intake and exhaust valves -- I don't know if that's necessary for DI.
Old Dec 13, 2005 | 05:05 AM
SSbaby's Avatar
Re: Direct Injection Compatible with Pushrods?
Don't know about the pushrods. I guess you know GM's HFV6 is direct injection capable?
Old Dec 13, 2005 | 07:39 AM
bossco's Avatar
As long as you can fit the injector in there somewhere its compatible. Aren't there some alchohol V8s running direct injection with a parrallel valve head? I think the injector is plumbed in from the exhaust side?
Old Dec 13, 2005 | 05:33 PM
Demon_Cleaner's Avatar
It is compatible. Remember the XV8? It had direct injection. Also, most newer domestic diesel engines use DI, and all are OHV.
http://www.acarplace.com/brands/gm/xv8-engine.html
Old Dec 13, 2005 | 06:59 PM
teal98's Avatar
I was aware of the XV8, but it has multiple camshafts. Its existence may be the answer to my question. What I didn't know was whether you really wanted separate intake and exhaust timing adjustments with DI. I'm guessing the answer is that you don't *need* it, but things work better if you have it. As far as I know, separate intake and exhaust valve timing adjustment requires separate cams.
Old Dec 13, 2005 | 07:41 PM
Jackass's Avatar
I don't see why not. Direct injection is just another form of fuel injection.
Old Dec 13, 2005 | 08:07 PM
91_z28_4me's Avatar
It would unless somehow you could have either the intake or the exhaust cam be a hollow design that is partly connected across. I am not explaining it well but I can picture a way that you can have limited VVT on both the intake and exhaust cams. It would not be easy but it might be possible.
Old Dec 13, 2005 | 08:22 PM
bossco's Avatar
IMO using 2 cams would be easier in a vertical arrangement for an OHV engine, interestingly Ford had a twin cam in block engine called the "calliope" I beleive it also had three valves per cylinder
Old Dec 13, 2005 | 08:27 PM
91_z28_4me's Avatar
I believe that Mercedes is the one that had a twin cam in block V engine back in the begining of the century.
Old Dec 14, 2005 | 12:21 PM
Gold_Rush's Avatar
It was an interesting engine.
A little read
427 3-valve "Calliope"
This engine was intended to run at LeMans, but rule changes outlawed it before it was ever fired. Displacing 427 cubic inches, it was out of place in a class limited to 183 CID. Two engines were produced. One even made it into a test car.
Even though mainly of aluminum construction, this monster weighed 577 lbs.
But it was no boat anchor. The Calliope produced 630 (supposedly reliable) horsepower at 6400 RPM.
While displacing 427 cubic inches, the Calliope was no FE family engine. It used an aluminum block engine with cast iron cylinder liners. Bore was 4.34", stroke was 3.60". The unique feature of this engine are its twin camshafts, one for the intake valves and one for the exhaust. Both are in the block in an over-under arrangement. The intake camshaft lies 6" above the crankshaft centerline. Pushrods from the intake cam run parallel to the cylinder bores. The exhaust camshaft is found 4.5" above the intake cam. Its pushrods lie in a horizontal plane. The camshafts are driven by chains as are the pressure and scavenge pumps for the dry-sump oiling system.
The aluminum cylinder heads feature 3 valves per cylinder, two intakes and a single exhaust, in a pent-roof combustion chamber. The heads are sealed with copper O-rings. No intake manifold is used. Hilborn style injection stacks are cast integrally with the cylinder head. No coolant passes between the block and heads. External water lines are used instead. To shorten the engine to assist in fitting it to the racecar chassis, the standard front mounted water pump is replaced by two pumps on the cylinder banks, similar to the scheme used on the Flathead V-8.
whitehooptie
Jul 22, 2015 10:25 PM
94Form
Jul 17, 2015 10:56 PM
RUNMYTA
Jul 15, 2015 07:50 PM
Jul 10, 2015 02:23 PM
