WB O2 in place of Stock O2
Old Oct 29, 2002 | 10:32 AM
dayusmc's Avatar
From: Stationed at Camp Lejeune, N.C. (But Going Home SOON!)- From New Jersey
Talking WB O2 in place of Stock O2
Would a WB O2 sensor work in place of the Stock O2? Would the PCM work with it.
I am asking because I am going to put a WB O2 sensor with Display in my car so that I can Moniter my A/F Ratio all the time. But I don't like to have too many extras. So If it is possible I would replace the stock O2 with WB and hook up a DIY WB kit to the same O2's. I don't think it would work, but I figured I would ask the experts.
Thanks!!!!
Old Oct 29, 2002 | 06:53 PM
BigDaddy's Avatar
No it won't work. The PCM isn't programmed to care about anything other than rich, lean, or stoic. The programming can't be changed either. www.techedge.com.au is working on a version of the DIY WB that will have the ability to convert the WB readings into NB format so they can be fed to the PCM. This doesn't make the readings going to the PCM anymore accurate, it just keeps the PCM from going crazy when you put the WB in place of the stock sensor. The new revision isn't on their website yet, but Peter has been talking about it on the mailing list. You can email him more about it if you like.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
