clutch not fully releasing?
Old Dec 10, 2005 | 08:07 PM
Berger1976's Avatar
I have an 01 Firehawk and when I get on it and go through the gears, it seems like the clutch has not fully released? The pedal is up all the way? It has done that since it was new and I have 24000 on it now Thanks Normal driving is OK
Old Dec 10, 2005 | 11:51 PM
TheNovaMan's Avatar
Re: clutch not fully releasing?
This tip is actually for Muncies, but it should work for any trans with a non-synchro Reverse. Let it run in neutral, step on the clutch and count to 10, then put it in reverse. If the clutch releases completely, it won't crunch. If you hear a crunch, you may have a clutch release problem.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
350350
14
Aug 11, 2015 12:03 PM
Jlo
Jul 29, 2015 03:52 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
