will putting 2.5" tips on a 3" dual exhaust cause a restriction?
Old Dec 8, 2005 | 11:23 PM
dhirocz's Avatar
I remember reading about this in a post but I couldn't find it.
I'm getting ready to ditch my borla catback for some borla true duals with XR-1's. Got it all planned out, but I want to use borla tips as well. Problem is, the type I want to use is the type that comes on the borla catback, and the biggest inlet is 2.5".
I read somewhere that as long as the pipe is 3" up to the tips that it will not cause a restriction due to the density and temperature of the exhaust at that point. Anybody have any insight on this?
Old Dec 8, 2005 | 11:30 PM
2000GTP's Avatar
Re: will putting 2.5" tips on a 3" dual exhaust cause a restriction?
I believe my old Edelbrock catback had a 3" intermediate pipe and 2.5 inch tailpipes and this exhaust still improved the power numbers.
Old Dec 8, 2005 | 11:32 PM
dhirocz's Avatar
so did my borla, but that was on a catback. The restriction there is the single 3" pipe. It splits off into two 2.5" pipes downstream. With the duals and X pipe with all mandrel bends, I'm just worried that if I choose the wrong tips it might cost me power since the 2.5" tips on duals would be the smallest part of the exhaust system.
Old Dec 8, 2005 | 11:51 PM
I burn rice too's Avatar
The theory sounds good and makes sense, but since you already have the tips, drive it around without the tips and then with the tips. Maybe even go to the track. Tips aren't that hard to install.
If your not really noticing a difference then the loss is more than likely minimal. If you go to the track post your findings.
Old Dec 8, 2005 | 11:55 PM
SS MPSTR's Avatar
You'll never notice the difference, honestly.
Old Dec 9, 2005 | 01:34 AM
2000GTP's Avatar
Or another thought is to install a 40.00 cutout before the muffler and end all the worries completely.
Old Dec 9, 2005 | 03:04 AM
1racerdude's Avatar
Will it cause a restriction--- yes
Will it matter--- probably not
Ya won't be able to feel it.
Old Dec 9, 2005 | 09:10 AM
By the time the exhaust reaches the tips, its cooled so much that you don't need as much cross-section on the pipes.
Buddy of mine had a 30th SS, with the 2OTL exhaust. He cut the 2OTL tip off and had it welded to the 4" taipipe on his Mufflex 4" catback, for that "stock" look. The car ran low 9's at over 150mph with the skimpy 2OTL tips.
Old Dec 9, 2005 | 10:32 AM
dhirocz's Avatar
Good. That's what I thought, I just wanted to be double sure before I started buying parts to do it. If I'm building the dual setup the last thing I want is to loose power from just a poor selection of parts.
Sergio
Jan 27, 2016 04:27 PM
alex5366
Feb 17, 2015 09:07 AM
MadMav
Feb 6, 2015 11:02 PM
Queens94z28
Nov 20, 2014 06:03 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
