Add traction control....
Old Dec 8, 2005 | 03:40 PM
devilisht2003's Avatar
how can i add it to a 95 Z???
Old Dec 8, 2005 | 03:52 PM
Dave89IROC's Avatar
Re: Add traction control....
buy a 95 F-body with it, then swap everything over..........
the things that are different are:
body wiring harness
dash harness
switch in dash
both rear brake lines(non tcs has 1, tcs has 2, both are different then the non cars)
brake lines on rear axle
rear axle(non had 1 ABS sensor on top of diff, TC had 2, one inside the rotors on each side)
the EBCM/EBTCM
the ABS HCU(unit under the hood)
the throttle cables(non had 1 , tc had 2 shorter ones)
throttle unit/black thing on the drivers side valve cover
possible PCM programing
Old Dec 8, 2005 | 04:03 PM
yeeeah kinda figured it would suck...thanks....guess i'l scratch that idea
Old Dec 8, 2005 | 04:20 PM
'86 350's Avatar
It's actually really easy, I did it to my '86. It's about a 2 minute job. Simply place a 3" block of wood under the pedal and be done with it! Works great on my car, good luck on the swap into your '95.
Old Dec 8, 2005 | 05:10 PM
lol riiight, i'm just gonna add weight to my Ttop well and drive it
Formula Steve
Sep 19, 2023 08:31 AM
NewsBot
Sep 14, 2015 09:20 AM
Aug 7, 2015 01:26 PM
Boss002
Jul 24, 2015 10:47 AM
surreybrad
Jul 5, 2015 10:36 PM
