Spherical Rotary Valve Cylinderhead...Wow!
http://www.coatesengine.com/csrv.html
Coates Spherical Rotary Valve Cylinderhead
Low manufacturing cost
Low maintenance cost
Low noise
Low parasitic power consumption
High efficiency
High volumetric efficiency
Flexibility of gas motion control
High torque/power density
High efficiency in part load operation
Low knock tendency
Low engine height for flexible vehicle styling
Low pollution emission
Alternate fuel compatability
Clean engine block and compartment
No liquid lube in any part of rotary valve
Low noise
High efficiency
Low knock tendency
Re: Spherical Rotary Valve Cylinderhead...Wow!
A friend of mine showed that website to me ~3 months ago and I kept meaning to post here about it as I don't understand enough about the design to really comment. So I'm interested to hear y'all's comments so I can pass them on to my friend.
He's convinced that this design will be found in almost every new motor on the planet within 5 years. I tell him that he might be reading too much into the manufacturer's hype and there's bound to be drawbacks as there is with almost any new tech. I don't know how many times I've seen or heard of a new tech and thought it would sweep the planet in a matter of weeks only to be disappointed.
Examples include electromagnetically actuated valve timing, magnetically controlled shocks, hybrid electric technology, CVT/IVT, etc...
How do these not require lubrication? Are they metal or Ceramic, I heard ceramic parts didn't need lubrication at higher temperatures?
It would seem like a natrual progression of OHC engines with the decreased area on top of the heads BUT I still don 't get how they expect it to not need lubrication, even the MAZDA Renesis engines eat a quart of oil every 5K miles or so.
Yep, I heard about it 10 years ago. It works off a similar principle as the Wankle engine, but in the actual valve train. Good thought, poorly executed.
You can also buy OHC conversion kits for small block chevys from Ardema.
-Shannon
-Shannon
-Shannon
-Shannon
http://www.aardemasohc.net/index_files/Page313.htm
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
