Headlamp switch relay??
When my headlights come on either auto or manual they work for a couple of minutes then turn on and off a couple of times and then off completely. Seems they try to turn back on every minute or so but instantly turn off. I have visualy checked what wires I can see behind the switch for a short but looks ok. I was told there's a relay inside the switch itself is this true? If so are they prone to just not working properly? If the switch IS ok what is the best way to check for a short? The marker lights turn lights and fog lights are all working 100%.
Re: Headlamp switch relay??
Headlight switches typically have a breaker in them, so if there is an excessive current draw, the lights shut off. This will keep repeating until the source of the draw is found. I guess it is not impossible for a switch to be bad, either.
Aaront810
Aug 29, 2020 09:34 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
jackpawt883
Sep 10, 2015 08:53 PM
