What are the pro's and con's of different size wheel front to rear?
Old Nov 26, 2005 | 10:46 PM
OreoLT1's Avatar
What are the pro's and con's of different size wheel front to rear like 17's up front and 18's rear? Also will 18x10.5's fit all around on a 02 Z28?
Old Nov 26, 2005 | 11:16 PM
Z95m6's Avatar
Re: What are the pro's and con's of different size wheel front to rear?
I would get the same size all the way around. I had 17's in the fronts 18's in the rear for a while. i got rid of them because i hated the fact that i couldn't rotate the tires unless i had the tires removed from the rims. Since almost all 17&18 inch tires for our cars can only spin one direction you have to get the tire switched on the rim to rotate the tires.
Jazsun
Dec 29, 2014 12:14 PM
Dec 4, 2014 11:56 AM
siguy
Nov 27, 2014 10:07 AM
