WTB: Stock USEABLE LT1 shortblock around Dallas
Old Nov 26, 2005 | 06:36 PM
whitehooptie's Avatar
I need a stock shortblock around Dallas for an LT1.
Old Nov 28, 2005 | 07:25 AM
mitchntx's Avatar
Re: WTB: Stock USEABLE LT1 shortblock around Dallas
Need one to install or rebuild?
Old Nov 28, 2005 | 09:17 AM
install
Old Nov 29, 2005 | 07:30 AM
mitchntx's Avatar
I have one that has a spun rod bearing ... I caught it before it did too much damage, though.
Old Nov 29, 2005 | 09:19 AM
Hhhmmmmmmmmm.......... How much?
Old Nov 29, 2005 | 10:05 AM
mitchntx's Avatar
Not sure what the going rate is for a rebuildable short block.
I got $900 for my '98 LS1 shortblock that needed a rebuild ... how about $450?
I even have a set of stock rods and pistons I would throw in. Because it has a spun rod bearing, It would need at least 2 rods replaced as they typically elongate the rod cap.
The reason I didn't rebuild it myself was last spring I was in a time crunch. I found a junk yard pull out to make the season opener and it has lasted all season.
Old Nov 29, 2005 | 11:25 AM
did it get the crank at all? I am not worried about the rods. I have plenty of those. I just don't want to go through with getting the block and crank prepped.
Old Nov 29, 2005 | 12:32 PM
mitchntx's Avatar
It definitely needs a close inspection. The crank, as I recall, had no gouges. But I just lifted the first rod caps and saw the bearings spinning around the journal.
When started, the motor definitely made a bad noise from down low, but held good oil pressure and ran on all cylinders.
Old Nov 29, 2005 | 05:23 PM
If you could give me a call I would appreciate it. I have a few more questions about it and it would easier to talk instead of type. My number is 903-217-3033. You can call anytime before around 1am.
Old Nov 29, 2005 | 06:10 PM
camaro79323's Avatar
i have one ill trade you for the front end
Old Nov 30, 2005 | 06:53 AM
mitchntx's Avatar
Sorry I missed this post
PM sent
Old Nov 30, 2005 | 12:30 PM
95 N2OT/A's Avatar
i have one in arlington just taken out runs great asking $1400 includes everything needed call me at 817 706 0012 if interested.
Old Dec 2, 2005 | 02:02 AM
I have currently purchased one. Thank you though.
I am always in need of some stock parts. Except lifters. I have 62 of them now. I don't need those. Anyone have any stock aluminum cylinder heads maybe? Or complete intake manifolds?
oldschool
Feb 9, 2016 09:21 PM
jb4xx
Feb 2, 2015 10:00 PM
97z28k&N
Jan 9, 2015 04:58 AM
Jul 4, 2005 05:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
