Ticking
Old Nov 16, 2005 | 02:30 AM
99Blackt/a's Avatar
Ticking
Ok, so I've had this ticking thats been going on for a while. Not a knock a true tick. I do have mac headers so could this be caused by the air tubes,i know ive read that somewhere but not sure how to fix that, also the car has only been overreved(sp?) and that was over 40k ago. On another note it was overreved(sp?) before the headers and did not tick at that point in time. I only started to notice this after the headers were installed. Could this be piston slap as well;however, why would piston slap develop after the headers, or am I just paranoid? Also, even when the motor was overreved(sp?) I never noticed a loss of power at all.
Old Nov 16, 2005 | 10:48 AM
teke184's Avatar
Re: Ticking
easy way to see if it's the air tubes would be to unplug the air pump, then take a piece of thin metal and block off the tubes where they bolt to the header. just sandwich the metal between the 2 flanges...
if it goes away you know what it is.
and if that works, i think you just have to drill a hole that is smaller than the existing tube, to restrict the air that goes into those tubes.
Old Nov 16, 2005 | 12:06 PM
99Blackt/a's Avatar
Re: Ticking
Ill have to give that a shot,i dont think its a pushrod b/c i would have noticed that before the headers would i have not? thanks for the info
Old Nov 16, 2005 | 12:48 PM
teke184's Avatar
Re: Ticking
most likely...
another possiblitiy that i just thought of was a sticking injector. but i'm not sure that would be loud enough to hear over the engine.
are you sure it's not an exhaust leak?? maybe recheck all your header bolts.
Old Nov 16, 2005 | 08:04 PM
99Blackt/a's Avatar
Re: Ticking
Ill check that too when I go home one weekend, thanks for the help, never thought bout the injector
Old Nov 17, 2005 | 03:01 PM
mmmchickenboy's Avatar
Re: Ticking
how is your oil pressure? does it tick when the motor is cold or after its warmed up? or all the time? does it vary with RPM? is it merely a loud fuel injector?
EDIT: try to check exhaust manifold gaskets too
Old Nov 17, 2005 | 03:19 PM
'99 SS's Avatar
Re: Ticking
I too noticed a slight "ticking" after installing my L/T's wile accelerating. I visited several shops, including the shop who did the installation. It was not anything inside the motor. The motor was never past 4K RPM.
They fabricated and installed "reducers" on the air tubes and that fixed the problem.
Old Nov 18, 2005 | 12:47 PM
99Blackt/a's Avatar
Re: Ticking
oil pressure is good, i dont think its an injector but from what i hear and the feedback ive received here im leaning toward either the air tubes or like you said teh exhaust manifold gaskets.
1slow93z28
Sep 1, 2015 06:22 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
importkiller94
Jan 17, 2015 09:03 PM
sc93
Apr 4, 2003 02:47 PM
Chris91Z
Mar 25, 2003 02:24 PM
