changing steering wheel on 4th gen
Old Nov 16, 2005 | 01:14 AM
zjet's Avatar
i have seen it but dont know how its done.removing the air bag wheel and changing to a regular style steering wheel
Old Nov 16, 2005 | 09:49 AM
Bud M's Avatar
Re: changing steering wheel on 4th gen
Its not really complicated. You remove the airbag, remove the stock wheel with a puller, install the new wheel's hub and then the new wheel. Then you will have the airbag light in the dash lit and you can cut the wire to turn that off.
Old Nov 16, 2005 | 11:39 AM
lt11997's Avatar
Make sure you disable the air bags before you do this. Take out the fuse and wait ten minutes before you mess around with the steering wheel.
Old Nov 18, 2005 | 09:40 PM
revtime's Avatar
Its pretty easy to do, I have a Grant GT wheel with a billet adapter on mine.
I had the cluster out and just removed the bulb to get rid of the lite.
Old Nov 19, 2005 | 01:26 AM
lt11997's Avatar
You could measure the resistance of the air bag and then put that size resister in the connector. That way if you get in a accident the passenger air bag still goes off.
If the air bag system detects a fault neither air bag will go off in a accident.
Old Nov 19, 2005 | 06:01 AM
Dave89IROC's Avatar
I recommend NOT measuring the resistance of the airbag, that might be enough to set the bag off
Airplanedoc
Feb 1, 2015 07:14 PM
Jason Short
Jan 19, 2015 06:33 PM
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
SLIMJIM
Jan 7, 2003 11:06 AM
