P1860 TCC PWM solenoid Circiut Electrical
Old Nov 11, 2005 | 10:22 AM
viper03af's Avatar
hello,
i just swaped in my A4 from Rossler and everything is fine but this code...... i got the wiring harness from SpearTech, and double checked everything........
can some tell me what else to look for?
also can this hurt the tranny in any way? or not let it shift right?
the TC is locking and this code comes on even without the car running key just "on" so i can scan
Old Nov 11, 2005 | 02:37 PM
Ricardo's Avatar
Re: P1860 TCC PWM solenoid Circiut Electrical
You probably got an earlyer (94) Transmission that does not have a PWM solenoid, just the TCC solenoid.
The strange thing is that the TCC is not supposed to be engaging if you get the P1860 code.
I have the situation described above after installing a built '94 4L60E in my '96 Z28.
There is one pin and wire less in the transmission connector, corresponding to the PWM solenoid.
I am going to delete this hardware verifation test from the PCM with LT1 edit but still have not got there. I am waiting for another part for the transmission to arrive.
Maybe someone else has done this before and can help with his experience.
RG
Old Nov 11, 2005 | 03:03 PM
viper03af's Avatar
its a 1999 tranny in a 1997 car... maybe thats it?
i'm at 2000 rpm @55MPH
thanks for the reply
Old Nov 11, 2005 | 04:57 PM
viper03af's Avatar
well i found it
SpearTech emailed me
then blue pin 22 is the one for that and i didn't have it in the PCM all the way....
thanks for your help
Old Nov 12, 2005 | 11:34 PM
Ricardo's Avatar
Glad to hear you got yours running right.
I got mine fixed too.
Removing the P1860 Hardware verification test with LT1 edit got rid of the SES light and got the converter TCC working.
'94 transmission in '96 car.
RG
Old Nov 13, 2005 | 10:03 AM
viper03af's Avatar
RG
lol i was about to do that with HP tuners i still ned to test drive the car i'm replace header gaskets right now
Old Aug 28, 2012 | 07:32 PM
Fred Willard's Avatar
I put a 94transmission in my 9696z28. I'm getting the same code can someone help me through the steps on how to go around this so i can get my car inspected? Thanks
Old Aug 28, 2012 | 09:55 PM
Ricardo's Avatar
Tune it out.
I have done this several times.
94 tranny driven by 96 LT1 PCM
94 tranny driven by 2002 LS1 PCM
football4life
Oct 4, 2015 07:48 AM
marlar98
Sep 19, 2015 07:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
jackpawt883
Sep 10, 2015 08:53 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
