Cam and wet kit - injectors?
Old Nov 10, 2005 | 08:48 AM
BD380's Avatar
I'm putting a CC306 in a car with a wet kit (stock heads). I'll be upgrading my fuel pump with the Racetronix kit, but should I get bigger injectors as well? Since it's a wet kit, obviously the larger injectors weren't a necessity for a bolt-on car, so I kept the stockers. What about after the cam goes in? Should I upgrade to 30lb injectors or will the stock ones be fine?
Old Nov 10, 2005 | 07:57 PM
n2oCamaro's Avatar
Re: Cam and wet kit - injectors?
I would get the bigger injectors for the cam.
Old Nov 10, 2005 | 08:35 PM
HarrisSpeedWorks's Avatar
Another vote for yes, it wouldn't hurt to upgrade them at this point.
Matt
Old Nov 10, 2005 | 10:05 PM
Kreinmc's Avatar
Stock will be fine. You will make 355rwhp at the most with the 306/stock heads and the stock injectors should easily support that kind of power.
Old Nov 14, 2005 | 03:31 PM
Jameslt1TA's Avatar
I agree. Friend on here is running a 306 with ported heads and 200 nx shot and running 10.19 on the stock injectors.
Old Nov 14, 2005 | 06:19 PM
n2oCamaro's Avatar
Though the stock injectors are supposed to support around 400hp, the duty cycle is completely maxed out at that point. If you do use the stockers and the duty cycle is above 90%, move up to something bigger.
Old Nov 14, 2005 | 09:53 PM
Nitro Dave's Avatar
Yes check the duty cycle on the injectors.Mileage plays a factor here also. If the injerctors are worn out they will have a high duty cyle also.
The stock injectors should be ok other wise.
Dave
alphaauto
Jan 23, 2015 07:42 AM
JamesN1830
Sep 11, 2002 10:57 AM
rje
Sep 9, 2002 12:35 PM
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
