whats the difference between 96-97 3.8 and 98+
Old Nov 1, 2005 | 06:13 PM
1994TransAm's Avatar
whats different block, heads tranny wise?
can i bolt a 2001 v6 into any 3.8 car?
Old Nov 2, 2005 | 09:36 AM
Chrisz24's Avatar
Re: whats the difference between 96-97 3.8 and 98+
I think I rember the newer 3.8's have a different position throttle body then the older ones. the 96-97 have a different intake then the 98+ sometimes the exhaust are a little different, 98+ were one piece welded and the 97- were bolted together.
I dont see why the engine's arent interchangeable.
Old Nov 2, 2005 | 03:37 PM
JaxCamaroGuy's Avatar
Also if i remember correctly they changed to tubular manifolds from the traditional cast iron heaps of metal which makes spark plug changes not such a PITA
Old Nov 2, 2005 | 04:23 PM
99blackSS's Avatar
Same here, both are series II 3800 engines.
Old Nov 2, 2005 | 11:43 PM
HBHRacing's Avatar
blocks are the same for all years. Intakes, throttle bodies, crank pullies, and other minor changes.
Old Nov 3, 2005 | 12:06 PM
deadmeat2004's Avatar
the engine will bolt up fine, i think. u will have to change a few things as stated right above.
GREEN3112
Feb 10, 2019 09:19 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
