roots and nitrous
Old Nov 1, 2005 | 01:48 PM
'74Z28's Avatar
roots and nitrous
I currently have a 177 on top of a 468 with 8:1, smallest pullies (2.5) on top. without the boost gauge should be pushing about 5-7psi. Car runs 11.8's as it sits would like to see 10's. I was thinking about a 100 shot. StockBBC rods, vanolia pistons, stock crank. Currently running 32.5 total timing with no detonation on 100 octane, had it dyno tuned. a/f perfect.
running 1050 dominator.
how much timing should I take out?
do you think that would be enough to hit 10.99?
any hints or advise would be greatly appreciated.
Old Nov 1, 2005 | 07:22 PM
engineermike's Avatar
Re: roots and nitrous
177 is WAY undersized for a 468. Put a T91 on that bad boy and run 8's.
Old Nov 2, 2005 | 09:37 AM
'74Z28's Avatar
T91? I would venture a guess that that was a Turbo? Do you have some pics of a turbo BBC setup?
Old Nov 2, 2005 | 01:27 PM
Damon's Avatar
Start conservative. I'd pull out 8* on a 125 plate shot and check the plugs as you go. Nitrous acts sort of like an intercooler for a roots application which helps offset a little of the detonation tendencides (I have considered doing it myself on my roots-blown small block) but you're still building cylinder pressure like crazy with it and intruducing a much higher oxygen content, speeding up the burn rate. It's not going to want as much advance as you have right now, that's for sure.
Old Nov 3, 2005 | 12:17 AM
ramair96ws6's Avatar
Man up ***** and start with a 200 and work from there
pull out 10-12 degrees of timing put a colder plug in it and have some fun
Or really man up throw that blower in the dumpster up your compression to 15:1 and spray it with a 300 shot and run 8s
Your loving freind
Steve
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
