how to tell if the PP is bad?
Old Oct 31, 2005 | 06:58 PM
Chevycobb's Avatar
I need to at least replace the disk(it's a spec...enough said) but I need to know if I can just get a new disk or if i have to replace everything. How can I tell if the pressure plate is bad?
If I can use the pressure plate again, do I have to go with a spec disk, or can I use any disk I want??
I'll hopefully have pics of the PP up soon if they will help any.
Old Oct 31, 2005 | 09:00 PM
Chevycobb's Avatar
Re: how to tell if the PP is bad?
nevermind about those pics...won't be able to get them up until wednesday. oh well..if anyone still has any info, let me know
Old Nov 4, 2005 | 08:36 AM
EKO's Avatar
EKO
If you have a Haynes manual, they have some photos in there of when you should replace the pressure plate. Basically if you have uneven or excessive wear on the fingers or if some of them are bent, it should be replaced. Also check the surface for imperfections.
Old Nov 9, 2005 | 11:37 AM
wrd1972's Avatar
Chances are the PP is fine, you can have it resurfaced by a clutch specialist to remove high spots. It seems that LT1 disks in general die much sooner than PP's. PM me if you want the number to local specialist who can reman the PP. He took my old LT1 PP and resurfaced and painted, it was almost too pretty to install.
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
