LT1 window switch tach signal problem
Old Oct 30, 2005 | 11:20 PM
RickS's Avatar
Can i wire my window switch to the white "tach wire" off the back of the pcm? The directions say to use the coil negative, but i would rather use the pcm.
are the voltages the same between the pcm's tach signal and the coil negative signal?
Old Oct 31, 2005 | 12:08 AM
Amped96's Avatar
Re: LT1 window switch tach signal problem
Yes, you can use that. That is how I wired mine. We tried wiring it off the coil and couldnt get it to work. Used the PCM wire and works perfect.
Old Jun 30, 2006 | 06:03 PM
Loadre's Avatar
Where is this PCM wire located?
Old Jul 1, 2006 | 11:25 AM
HarrisSpeedWorks's Avatar
Pass. side, under the cowl.
Matt
mr28
Apr 20, 2016 05:44 PM
Injuneer
Dec 15, 2014 09:36 AM
mr28
Nov 23, 2014 11:11 AM
Ryabut98
Sep 3, 2002 11:45 PM
