Cable for TunerCat and 94-95 LT1's
Old Oct 27, 2002 | 11:01 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Question Cable for TunerCat and 94-95 LT1's
I apologize for the newbie question, but I did a search and couldnt find anything.
For those of you using TunerCat, what cable are you using to read/write your 94/95 PCM? The AKM cable? I have Diacom and the cable for it, will that work?
Thank you.
Old Oct 27, 2002 | 12:51 PM
TA25th's Avatar
I got my cable from here:
http://wotelectronics.com/cables.html
I don't know about the Diacom cable, but if it connects to the serial data and ground lines on the OBDI connector, it should work. That would be the two pins to the farthest right on the connector. (Top right and bottom right pins.)
-Shawn
Parts Wanted
Mar 17, 2015 11:24 PM
edman
Jan 25, 2015 02:41 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
