Stock bottom end??
Old Oct 25, 2005 | 10:51 AM
sunsetorangess's Avatar
Stock bottom end??
I'm fixing to start spraying and the only thing i'm worried about is the stock bottom end. I plan on making around 500rwhp with the spray(100,125 shot). Is this safe for an ls1 stock bottom end? How much could it handle?
Old Oct 25, 2005 | 12:10 PM
HarrisSpeedWorks's Avatar
Re: Stock bottom end??
As long as your tune and fuel system is good you'll be fine. The stock bottom end can take a lot, to around the upper 600s. Make sure you're running good plugs, pull some timing, and make sure fuel pressure is good and you'll be good to go.
Matt
Old Oct 25, 2005 | 12:51 PM
speedyjr's Avatar
Matt
extaly what I would have said.
Old Oct 25, 2005 | 10:40 PM
Alrite good. Thanks.
Old Oct 27, 2005 | 12:48 PM
Steve96WS6's Avatar
A friend of mine has a 98 TA and he is spraying a 200 shot and has been for 3 years with no problems. His car has a cam and bolt-ons with good susp and runs 10.90's with a 6 speed.
canbaufo
May 25, 2015 12:01 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Killer94z
Jan 13, 2015 12:06 PM
97 RedSS
Jun 10, 2003 07:58 PM
