brakes
Old Oct 27, 2002 | 02:10 AM
k9pusher's Avatar
brakes
If I were just to replace the stock rotors with larger ones before I do a blower would that be enough or should I go with an entirely new system like Baer?
Old Oct 27, 2002 | 03:28 AM
chuck's Avatar
For normal street use or drag strip duty, the stock brakes with better pads and good fluid will do just fine. I would suggest Hawk HPS pads and Motul 5.1 fluid.
The next step up, which won't shorten stopping distance much if any, but will give longer performance and repeatability before brake fade under road racing conditions where you are using the brakes hard and often would be the LG G-Stop kit with Z06 calipers. It is basically Z06 front brakes for your F-body. Still use good pads and fluid.
The next step up from that, and so close to the higher priced Baer and Brembo setups would be the Porsche Big Red kit from Prospeed.
No matter what you do stick to stock pads out back.
Old Oct 27, 2002 | 02:27 PM
mook99TA's Avatar
I saw that someone said to stick with stock pads in back? Why not change all pads?
Old Oct 27, 2002 | 03:08 PM
chuck's Avatar
Because LS1 F-bodies have too much brake biad dialed into the ABS, and will axle hop under hard braking:
http://chuckb.1le.net/racing/drivers...r/axle_hop.wmv
More rear brakes make it worse.
Old Oct 27, 2002 | 03:35 PM
k9pusher's Avatar
wow...thanks chuck
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
