New to owning LS1
Old Oct 14, 2005 | 01:40 PM
97QuasarBlue3.8's Avatar
New to owning LS1
New to owning an LS1...I have an '00 Z28 w/ 50k.
I don't know what kind of oil it has in it now...should I switch to synthetic, or maybe a synthetic blend? Is that recommended for a motor w/ 50k on it?
Is there anything prone to failure or early wear, or anything else I should check for? It has the SOTP wow factor down pretty good ...now I just want to keep it in good shape through 100k.
Old Oct 14, 2005 | 03:01 PM
SSpdDmon's Avatar
Re: New to owning LS1
I like Castrol Syntec 5w-30. Don't need synthetic as long as you change the oil every 3,000 religiously. Don't freak out about the temp guage...it's a dummy for the most part. Keep an ear out for audble pinging. Some 2000's knock from the factory when they're floored. Oh, and get yourself some subframe connectors for "preventative maintenance" (and better handling).
Old Oct 14, 2005 | 03:15 PM
That's another question I have....what are the "normal" pegs for the temp and oil pressure gages when the car is warmed up? My old 3.4 and 3.1 used to drop to between 4-8lbs of oil pressure at idle, but everyone said that was fairly normal.
Old Oct 15, 2005 | 12:29 PM
00cls1camaross's Avatar
my temp is a little bit less than 210* and my oil normally is ~40 somtimes it goes to 60+(which is fine from what i have read here)
-Dakota
Old Oct 15, 2005 | 10:35 PM
Greed4Speed's Avatar
99+ temp guages are dummy guages. They'll rise to a given point and set there.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
meissen
Jun 1, 2015 07:59 AM
