What factors make a shock a good match for a spring?
Old Oct 14, 2005 | 11:26 AM
CheshireCat's Avatar
I've read here on the board that Bilstein HDs are a pretty good match for stock springs on a Z28...
I've also read that for most lowering springs the Bilstien's should be valved differently to compensate for the higher spring rates and lesser travel...
Manufacturer Model Front (lbs/in) Rear (lbs/in) Ride Height Drop
OEM GM V8 93-97 310 110 0.00"
Hotchkis Fbody Springs 285-525 100-140 1.00"
Manufacturer Model/Location Bump Rebound
Bilstein HD Front 159 279
Bilstein HD Rear 86 174
Now I'm figuring that there is some way to calculate the ratio of spring rate to both bump and rebound taking into consideration the weight loaded onto the springs and the travel of the springs...
Now the variable rate springs sound good in concept, but how do you get a proper shock to dampen a spring rate that varries from 285-525 pounds/in???
Thank's
Steve
Can anyone tell me how to calculate this???
Old Oct 14, 2005 | 01:20 PM
Norm Peterson's Avatar
Re: What factors make a shock a good match for a spring?
I guess you'd have to work with the equations for damped vibration of a spring-mass system. But it takes some experience to know just what velocities that you're damping and what percentage of critical damping (perhaps range of percentages) to use. Maybe somebody else can help with the specifics . . .
Give Sam Strano Jr. a call ( www.stranoparts.com ).
Norm
Old Oct 14, 2005 | 02:37 PM
Thanks, I've read many of Sam Strano's posts, and I've learned a lot from him... I'm really just trying to learn more about suspension... Sam is very generous with information and I'm sure he could teach a course on the subject, but I'd be asking him to give me the shock (damper) 101 course and then I'd want to attent 102.. He has a business to run and races to win... If I ever get the budget together to do it right, I'm going to call him to order my setup...
For now, I'm just trying to learn the theory...
Old Oct 14, 2005 | 02:48 PM
lt1aggie's Avatar
you might get more attention over at http://frrax.com
97TA-WS6-Con
Feb 1, 2015 01:01 PM
95chwagon
Jan 13, 2015 09:19 PM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
