Doesnt want to go into reverse all of a sudden (T56)
Like the subject says, last night, got off work, went to the grocery, when I came out, the car didnt want to go into reverse. Still doing it now. It will go in, but it is harder to push to the right to get to the reverse gate, after I get it to the right, it pushes up into gear just like normal. It is almost as if the reverse lockout is going out, is that possible, or am I looking at another problem? Any way to find out for sure?
Re: Doesnt want to go into reverse all of a sudden (T56)
Its possible you have a problem with the reverse lockout solenoid. If it doesn't work, its very hard to push past it into reverse. Check the fuse (#6 in the under hood panel on your 95).... it also supplies power to the skip shift solenoid and a few other items.
