panhard lowering bracket
Old Oct 12, 2005 | 06:59 AM
teke184's Avatar
just noticed this in the Jegs catalog
http://www.jegs.com/webapp/wcs/store...chItemId=96983
Old Oct 12, 2005 | 08:48 AM
teke184's Avatar
Re: panhard lowering bracket
this is different from the upper panhard brace kit which allows running dual 3" pipes over the axle.
it's supposed to restore proper geometry after lowering. the adjustable panhard can recenter the axle, but the geometry is still off.
anyone?
Old Oct 12, 2005 | 08:49 AM
JakeRobb's Avatar
Super Moderator
Did you have a question?
Old Oct 12, 2005 | 10:04 AM
teke184's Avatar
sorry...typed it in a hurry...
does anyone use it? think it is worth anything on lowered cars?
i've never seen it or heard of it...
Joe 1320's Avatar
I think it is a worthy part. Fred and I were discussing this when I added the BMR panhard relocation kit for additional exhaust clearance. The debate is if the car is lowered, do you still need the panhard lowering bracket. It appears that if the panhard rod is parallel to the ground, you will still get body movement. When the suspension compresses, the body will shift to one side, when the suspension uncompresses, it will move the other direction. Granted the movement will be minimal, but it will still be there. Ultimately a different setup like a watts linkeage is in order.
http://tsmmfg.com/Watts_Linkage.htm
Old Oct 12, 2005 | 07:15 PM
Bud M's Avatar
More info regarding lowering the phb:
http://frrax.com/rrforum/index.php?act=ST&f=3&t=5624&
http://frrax.com/rrforum/index.php?act=ST&f=3&t=5571&
thenewkid
Apr 12, 2015 07:42 PM
HectorM52
Jan 31, 2015 07:29 PM
thenewkid
Nov 27, 2014 09:41 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
