Can I remove this safely?
Old Oct 5, 2005 | 11:37 AM
95patriotZ's Avatar
The small black metal "brace" that is under the passenger seat that goes across the I-pipe. Can I ditch this? It has been rattling and causing vibrations under acceleration. I have used a grinder and notched it out and tried prying it down further and still it hits the exhaust. Has anybody did this?
Old Oct 5, 2005 | 11:39 AM
anaik's Avatar
Re: Can I remove this safely?
I put some washers between the brace and the body.
Old Oct 5, 2005 | 11:46 AM
95patriotZ's Avatar
good idea! Never thought about that. I will try it! Thanks
Old Oct 5, 2005 | 11:49 AM
izzyz28's Avatar
I also used about three washers on each bolt and it works like a charm!
Old Oct 5, 2005 | 02:44 PM
3gc's Avatar
3gc
Check to see if your transmission mount is worn. As they get old and wear they compress which will cause the exhaust to hang a little lower. I replaced mine with a new GM one and the new one was atleast 1" taller.
Boss002
Jan 20, 2016 12:17 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
Jul 10, 2015 02:23 PM
