3rd gen rear and 11" ZR1's?
How do you guys think the 11" wheels would look bolted up to a 3rd gen rear? Since they're narrower by 1.5" each side or so, and the 11's stick out a bit...
Would they be set IN too far that they'd hit the inner fender/frame? Any ideas? Thanks!
Re: 3rd gen rear and 11" ZR1's?
Check out Skulte Performance Designs..... he has "adapters" for the 3rd Gens. They act as "spacers", but they are much stronger since they bolt directly to the stock hubs, and have a new set of studs for the wheels to bolt to. Not cheap, but they would work.
http://www.skulte.com/info_pages.php...9e453a4a9e28d9
There's no way to install them on a 3rd gen without the adapters (unless you want to tub the rear end). And I'd think that you'd still probably need to do some massaging of the wheel well with these adapters.
Originally Posted by kandied91z
even with adapters not very good. your best bet would be to massage the inner fenders a bit then it could look good.
hammering would absolutely be necessary to fit them properly inside the wheel well completely which was the point. meaning that yes adapters will work obviously but with just adapters and nothing else it won't look good. with some inner massage work and the proper measurements for the right spacing then yes they should fit just fine. if you shoot for a 6.25" backspacing measurement an 11" rim should fit with very little issues. you will have to remove the bumpstop and hammer in the support as this is where the wheel will rub at that backspacing. if you go to a larger backspacing you will need to do more extensive work and if you go smaller then the wheels will stick out.
good luck.
good luck.
Yeah, but he's trying to put 17x11 ZR1s on a 3rd gen. AFAIK, the ZR1's are only available with an offset/backspace appropriate for 4th gens and 'Vettes. That means that the wheels, as Injuneer said, will be waaaay too far into the wheelwells to work (without the adapters).
F'n1996Z28SS
Aug 23, 2023 11:19 PM
