IS the Traction Control switch a momentary switch?
Old Sep 15, 2005 | 02:40 PM
2QUIK6's Avatar
Trying to find out if the TCS switch in the 98-02 f-bods is a momentary type switch?
I have a '95 TA that I'm putting a 98 center console in and want to put the "Transmission Perform" button in the slot where the TCS switch would normally go, and will need to use the TCS switch from the LS1 cars if it will work the same way the little Transmission Perform buttom works in the LT1 cars.
Old Sep 15, 2005 | 06:23 PM
slopokrodrigez's Avatar
Re: IS the Traction Control switch a momentary switch?
Both switches are momentary BUT the 98 may only have one pole and the 95 requires 2 pole. It's not clear in the schematic if the 98 switch has 2 poles or not.
Old Sep 15, 2005 | 07:01 PM
2QUIK6's Avatar
Well the '95 Transmission Perform button is only 1 pole which is what I want to use it for anyway instead of TCS.
Old Sep 15, 2005 | 08:50 PM
scmudslinger's Avatar
Excuse me, but what exactly is the "Transmission Perform" button?
Old Sep 15, 2005 | 09:21 PM
2QUIK6's Avatar
Its a button that was an option on the 94-95 TAs that when pushed caused the tranny to use different tables in the PCM changing the shift points and increasing the main line pressures which makes the shifts firmer.
Here's some reading on how to make one in a Camaro
http://members.***.net/chipsbyal/page/trans/page3.html
Also, I pulled the TCS switch out of my '99 TA and it has 5 wires going to it..don't know if that means its a 1 pole or 2-pole though.
Javi Fierros
Jun 10, 2015 03:35 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
