Does this look right? (waterpump pic) 98Z
Old Sep 11, 2005 | 01:05 PM
dtp's Avatar
dtp
Question Does this look right? (waterpump pic) 98Z
http://img92.imageshack.us/img92/5779/waterpump4zy.jpg
I've been slowly losing coolant over time. No white smoke or stuff dripping out of the exhaust. But I noticed coolant on the front of the engine, on the drive belt and various stuff on the front of the engine. I don't see leaks from any hoses so far but look at the picture. Does it seem like the hose pointed to is not completely on the water pump? This may explain my unable to solve squeeky drive belt problem (slippery coolant water on belt).
I'd appreciate any opinions on this, maybe I just need to slide that hose up and if so... Does GM service remove this hose when doing radiator service? If so, this is f'up #3 for them in my book...
I have not got a really good look at the water pump yet, the top looks good, but I'll check out the bottom later today unless someone looks at this pick and says, "Damn right that hose needs to be moved up on the connector!"
Old Sep 11, 2005 | 01:28 PM
2001NBMZ28's Avatar
Re: Does this look right? (waterpump pic) 98Z
Mine looks the same...never been touched...
Old Sep 11, 2005 | 03:48 PM
dtp's Avatar
dtp
Thanks, ran the engine for a while and didn't notice any leak from there anyway or around the waterpump or any hoses. But somehow coolant got on the front of the engine and some of the metal lines/tubes routed around the front of the engine. I almost wonder if the damn thing leaks when it's just sitting around since I gave it some coolant about a month ago and went on vacation for a week, then had the coolant light come on when I drove it when I got back... Ah the fun of owning a an f-body :-).
Old Sep 11, 2005 | 04:34 PM
2001NBMZ28's Avatar
If you can't find the leak yourself you can take it to a shop and have them put dye in the system, then they shine a special light on everything, that'll pinpoint the leak.
Old Sep 11, 2005 | 04:38 PM
dtp's Avatar
dtp
Thanks, I'll have to do that, so far I have no idea even though I'm suspicious of the water pump.
Old Sep 11, 2005 | 06:47 PM
dtp's Avatar
dtp
MMm... cleaned everything off and ran the car some more and finally, I found some coolant forming on the underside of the water pump. Can't see the exact source, but it appears to be coming from the front of the pump. I guess I need a new waterpump or do I?
Also if I decide to change the pump, are there other accessories I need to buy? I'm guessing at least a gasket and some gunk.
Old Dec 11, 2010 | 05:19 PM
dtp's Avatar
dtp
Ah another coolant leak mystery. See coolant on my AC compressor of all places, at least on the bottom of it. I see some coolant along the left edge of the oil pan too. Having a hell of a time determining the source to see if it's time for another water pump.... The drive belt squeaks occasionally and I suspent coolant of whatever is leaking on that.
Changed the steering rack a couple weeks back but the steering liquid is much thicker than the watery orange stuff I'm seeing here.
Old Dec 12, 2010 | 01:33 PM
GreenDemon's Avatar
It sounds like a bad water pump to me. Usually when the bearing starts to go out coolant will start leaking out of the front, and the pulley will tend to fling it everywhere. If you're seeing coolant in a bunch of different places on the front of the engine I would suspect that first.
Old Dec 12, 2010 | 01:53 PM
BandDirector Blk98ZM6's Avatar
There is a small "weep hole" on the waterpump that leaks coolant when the pump starts to go bad. My '98 Z was doing that on the my original LS1 and the dealer replaced it under the extended warranty I had at the time...
Old Dec 12, 2010 | 08:26 PM
dtp's Avatar
dtp
Any idea where this 'weap hole' is on the pump? Ugh, changing the water pump was a PIA last time I did it. The coolant I've seen so far seems to be on the right side of the front of the engine primarily, some on the AC compressor, K member, didn't notice any directly below the water pump, but it's a bit hard to see everything without removing crap.
Old Dec 19, 2010 | 01:17 PM
It's been years ago...I don't remember where exactly the coolant was leaking, but there was enough coming out that my first sign I had a problem was when I was sitting at a red light and noticed just a little bit of steam coming out from underneath the hood...by the time I got to my destination, there was enough coming out that there were drips under the car of coolant.
Fastbird93
Jul 11, 2015 04:37 PM
colts0455
Jul 8, 2015 12:21 AM
cmsmith
Jul 5, 2015 07:23 PM
nikolt1
Feb 27, 2015 09:10 PM
