Anyway to permanetly disable VATS...need quick help...
Old Aug 27, 2005 | 11:30 AM
Korben's Avatar
So...turns out that the brain of my alarm was fried9aftermarket alarm). I started cutting it out......All of the wires and all the bull**** that the previous people had installed.
Well, everything turns on fine now, but the engine won't crank over. Yea, security I think. That HAS to be it. Noc licking, no nothing. battery is fine, everything else is fine, it ran a few hours ago until I decided to get kung foo on the bitch. Anyone know which wire/what to do to permanetly disable VATS so I can get the ***** running again?
Can HPtuners delete a code that will fix it? Thanks folks.
Old Aug 27, 2005 | 01:01 PM
Re: Anyway to permanetly disable VATS...need quick help...
The general tech forum is filled with VATS disabling posts. You will have to bypass the theft deterrent relay AND buy a VATS bypass module or have it programmed out of the computer.
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 11:56 PM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
