rocker arms?
Old Aug 26, 2005 | 05:19 PM
cc89formula's Avatar
rocker arms?
are the rocker arms on a stock LS1 roller, or atleast a roller tip? or are they just the stamped junk? just wondering...never been inside an LS1.
Old Aug 26, 2005 | 06:30 PM
Greed4Speed's Avatar
Re: rocker arms?
Roller fulcrum not roller tip. They will handle just about anything you'll throw at them.
Old Aug 28, 2005 | 12:39 AM
Re: rocker arms?
do you know why its a roller fulcrum and not tip? just seems kinda odd to me. also do you know how they are mounted? i kinda wonder if anyone has used them on a gen 1 or 2 head???
Old Aug 28, 2005 | 02:13 AM
99Blackt/a's Avatar
Re: rocker arms?
Cant tell you why its a roller fulcrum and not tip but I know they are pedistal mounted not shaft mounted
Old Aug 28, 2005 | 10:14 AM
muraoka's Avatar
Re: rocker arms?
stock rockers are fine. they say about .630 lift is max though. but alot of different things come into play. they won't work on any other chevy head.
i have patriot golds and 611/619 lift spin to 6800 stock rockers and lifters no problems yet.
matt
Old Aug 28, 2005 | 11:36 AM
Re: rocker arms?
Probably because the fulcrum would be a larger contact area and therefore cause more friction than the tip.
Old Aug 29, 2005 | 05:13 PM
mrr23's Avatar
Re: rocker arms?
because the roller tip is a myth of it working. if you've ever put a timing light onto a rocker while the engine is running, you'll notice the wheel doesn't move at all. but, the idea has been around for so long, it has stayed. crane cams is currently looking into making a roller pad instead of wheel.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
