Advance Auto Parts scanner says I must plug device in....?!?!?
Old Aug 24, 2005 | 06:26 PM
Kurt Crosbie's Avatar
The last two times I went to pull the codes from my pcm at AAP, their scanner doesn't seem to be detecting my computer. It just tells me something like "Device must be plugged in" or something. I plug it in and turn the scanner on just like I always do, but now it wont work. What the heck is going on?!
Old Aug 24, 2005 | 06:29 PM
Eff's Avatar
Eff
Re: Advance Auto Parts scanner says I must plug device in....?!?!?
is the key on
Old Aug 24, 2005 | 06:32 PM
yep
Old Aug 24, 2005 | 06:40 PM
moparman's Avatar
Since you have a '95, I bet they're plugging an OBDII code puller in, and it won't work.
Old Aug 24, 2005 | 06:57 PM
Well, i have an obdI pcm and I was using an obdII connector because that is the kind of connector I have. Keep in mind I was successful at scanning at this same place before with the same type of device. Are you saying that possibly they have two identical looking scanners and only one of them scans obdI? What would be the purpose of them having multiple connectors in that case?
Old Aug 24, 2005 | 08:46 PM
LT4orbust's Avatar
you have to set the scanner up to read the pcm thats in it now ,not the year it actually is
edit, i didn't read enough.... i thought you changed to obd1 from obd2
Old Aug 24, 2005 | 09:21 PM
moparman's Avatar
If they were able to pull codes on your '95 before, they should be able to do so now. Not knowing what kind of equipment they have, I'd hesitate to make a guess as to why it won't work now.
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Injuneer
Dec 15, 2014 09:36 AM
Sarahrope64
Nov 27, 2014 11:17 AM
