KDWS in front KDW-KD in back?
Old Aug 22, 2005 | 07:35 PM
blind527's Avatar
Would this be a good match? Are the KDWS a good front tire? What would it be like to have KD-KDW in the back with the KDWS in front? I can't find out any information based on my questions.
Old Aug 22, 2005 | 07:43 PM
Greed4Speed's Avatar
Re: KDWS in front KDW-KD in back?
If you want to stop fast, you need a good soft tire in front. If you want to take off fast, you want a good soft tire in the rear.
What is your plan for the car?
Old Aug 22, 2005 | 08:53 PM
blind527's Avatar
I don't have immediate "power" plans right now, but I would like:
LE type 3 heads and type 3 cam along with full suspension. I have the KDWS in the back right now.
Old Aug 24, 2005 | 06:09 PM
Jeremy95LT1Form's Avatar
Right now I have BFG KDW's on the front and Goodyear GS-C's on the back. The Goodyears are a little old, but I purchased a few before they disappeared. Anyhow.
I was always told to not mix and match tires. Each tire handles a little different and will break loose at a different point. So I was told that if you plan on driving the car hard you might be asking for trouble? As for me, I have driven my car hard and no problems yet. The Goodyears are running thin and soon I shall have matching tires again. I could be totally wrong, but it sounded reasonable to me.
Old Aug 27, 2005 | 08:36 PM
blind527's Avatar
Would anyone recommend the KD(W) rear and KDWS in front? Thanks for your help.
Old Aug 27, 2005 | 08:50 PM
Zack's Avatar
i wouldnt recommend the kdws at all
Old Aug 27, 2005 | 08:53 PM
blind527's Avatar
Well if you read, I already have them in the back. I have heard good things about them. I tried getting the KD's and the KDW's for the back but it would have taken over 2 weeks to get them and I needed new tires taht day. I'm gonna keep the KDWS on the car since I already have them, and just put them in the front if I get KD.
Old Aug 28, 2005 | 07:31 AM
SFB767's Avatar
Question Re: KDWS in front KDW-KD in back?
Why?
Old Aug 28, 2005 | 04:51 PM
blind527's Avatar
I just noticed that my front passenger side stock Goodyear tire is dry rotting severely. I have a Yokohama AS430 or something on the drivers side. Should I replace both the Yokohama and Goodyear with the KD or KDW and put the KDWS in front? I need to know if putting the KDWS is ok. I also need to know if I put a KD or KDW in the back is ok. I also thought about putting some Nittos in the back, and putting the KDWS in the front. I need to know info on this asap! What is the biggest size I can put on the back of my car? I thought about getting either 255/?/16 or 275/?/16. I really need to know this info! Nevermind, I found out that 255 is the biggest size on my wheel.
I have an idea: Nitto 555R's in the back: 245/50/16 and the KDWS in the front.
Old Aug 29, 2005 | 01:02 PM
SFB767's Avatar
You'll like the BFG g-forces.
I'm about to buy my 3rd set in the next few months.
They're good at everything.
Old Aug 29, 2005 | 01:09 PM
JakeRobb's Avatar
Super Moderator
I have 245/50/16 KDWS all around. I like them okay, considering that they have decent snow traction. Turn-in response and slip angle are good. Accelerating and braking traction are okay, but leave something to be desired. The W speed rating (168mph) is nice. Tire noise is minimal.
If you don't live in an area with snow, or don't drive your car in the winter, don't bother with the KDWS. (The S stands for Snow). If you don't get a lot of rain, or don't drive your car in the rain, don't bother with the KDW either. D is Dry, W is Wet, S is Snow. The KD has awesome dry traction. The KDW and KDWS sacrifice some dry traction for wet and snow capabilities, too.
I'll probably try something different when these wear out, but I don't know what yet.
-Jake
Sergio
Jan 27, 2016 04:27 PM
Jazsun
Dec 29, 2014 12:14 PM
ModdedNerd
Dec 25, 2014 05:51 PM
