ratchet shifter?
Old Aug 10, 2005 | 11:32 PM
nonojoe66's Avatar
ratchet shifter?
i see all these threads about people who put ratchet shifters in 4th gen a4s but i also see threads about how its bad to manualy shift a stock a4? i want to put a ratchet shifter in my 93 but i dont want to damage anything, would it be best to put a manual valve body in it? what is the difference between a manual valve body and a reverse manual vavle body? is it just that with a reverse one u pull the shifter back to upshift and with a regular one u bump it forward to upshift?
also would a manual vavle body eliminate overdrive? or is it just like having a 4 speed?
Old Aug 11, 2005 | 08:12 AM
LT1LE's Avatar
Re: ratchet shifter?
You Do Not Need A Manual Valve Body....
A Manual Vb Goes P R N 4 3 2 1
A Reverse Manual Vb Goes P R N 1 2 3 4
You Will Still Have 4.th With A Manual Vb
Old Aug 11, 2005 | 12:20 PM
nonojoe66's Avatar
ok so its not bad to manualy shift a stock 700r4?
Old Aug 12, 2005 | 01:51 AM
LT1LE's Avatar
DO A SHIFT KIT AND YOU'LL BE FINE.
NOT A BED IDEA TO DO THE:
Elevated Pressure Regulator Spring
throttle valve elevated pressure spring
low / reverse boost valve
heavy 1-2 accumulator spring
http://www.transmissioncenter.net/highperf700r4.htm
Old Aug 12, 2005 | 01:21 PM
BLinindoll's Avatar
4th gens have 4L60e's. not 700r4's. and yes, its not good to manually shift a 4L60e because it creates too much line pressure.
Old Aug 12, 2005 | 05:52 PM
ltwonz's Avatar
93's have a 4l60 or also called a 700r4 not a 4l60e. You can also put in a manual/automatic vavlebody like i have. If you put it in drive it will shift itself or you can shift the car threw the gears.
Old Aug 13, 2005 | 12:42 PM
BLinindoll's Avatar
jeez... i keep forgeting to check to see if were talkin about a 93. I always forget the're different. they should just be called 3.5 gens, hehe.
Old Feb 23, 2006 | 09:35 PM
1SLOSBC's Avatar
old link, but i was searching.
incorrect info.
a reverse manual valve body shifts this way.
it is the only one available for the R4 and 60e so yes, it will shift as you post, but other trannys still have the regular forward motion, even with a manual valve body.
its just this particular tranny that is fubar.
blac94Z
Nov 4, 2015 01:59 PM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CARiD
Sep 7, 2015 08:21 AM
