Free Ram Air?
Old Jul 29, 2005 | 05:00 PM
black02z28's Avatar
Free Ram Air?
I am doing the free ram air mod today,but it says I need a demel tool to cut the baffle,but I don,t does anyone know another way to cut the baffle out i,m stuck here ?
Old Jul 29, 2005 | 05:20 PM
StudyTime's Avatar
Re: Free Ram Air?
Are you serious???
A razor knife cutting away little half-moon shapes one stroke at a time followed by smaller slivers until you get to a prescribed line. This approach may work, but I'm cautious to tell you this. It would be very easy to cut yourself this way, and also very easy to remove too much material if you get over zealous while trimming. Be prepared for it to take a while if you want a good end result.
Ben
Old Jul 29, 2005 | 05:25 PM
ChicagoTransAm's Avatar
Re: Free Ram Air?
oh dear
Old Jul 29, 2005 | 07:19 PM
QuickSilver02's Avatar
Re: Free Ram Air?
Did you mean dremmel?
Old Jul 29, 2005 | 07:22 PM
Z28WannaB's Avatar
Re: Free Ram Air?
Don't do that to your bumper.
If you can't afford RAM air you can't afford RAM air.
Don't be ghetto. This mod is on par with wrapping a fuse with copper because your too cheap to buy a new one.
- Z28WannaB
Old Jul 29, 2005 | 08:00 PM
black02z28's Avatar
Re: Free Ram Air?
The free ram air mod is complete thanks guys for your help?
Old Jul 29, 2005 | 08:01 PM
myslowcamaro's Avatar
Re: Free Ram Air?
- Z28WannaB
correct me if im wrong, but if you go with some cai's like ssra, you need to do this anyway
Old Jul 29, 2005 | 08:03 PM
99blackSS's Avatar
Re: Free Ram Air?
I am against this mod because it only works in theory and the theory leads to a very dirty air filter.
Yes, it can be done without a dremel, I did it on my V6 Camaro before I owned a dremel. I used a sharp pair of pliers. I recommend just buying a dremel you can get a cheap one for around $20-$30. Mine has become pretty handy.
Also, if you truly believe in ram air on cars, you have to block off the stock intake opening.
Old Jul 29, 2005 | 08:28 PM
black02z28's Avatar
Re: Free Ram Air?
SSRA is next mod for me.
Old Jul 29, 2005 | 08:32 PM
teke184's Avatar
Re: Free Ram Air?
personally i don't think the FRA mod is what the name implies.
it really isn't a ram air....it's more of a less restrictive air box.
how easily do you think it is for the engine to pull air through that 10x3/4" slot on the front of the air box??
if you can increase the exposure of the filter to outside air, you'll get better performance.
if the filter is getting dirtier i would say taht is a pretty good indication it's getting more air.
and YES....the ssra does require the FRA mod to install it...
Old Jul 31, 2005 | 01:55 PM
94zLT1's Avatar
Re: Free Ram Air?
"Also, if you truly believe in ram air on cars, you have to block off the stock intake opening."
__________________
Umm why would you have to do this? air can come in from both under and front? 2 places are better than one
Old Jul 31, 2005 | 03:02 PM
99blackSS's Avatar
Re: Free Ram Air?
__________________
Because your not getting the theoretical ram air effect if you have a second opening the pressurized air can getout through. Many of the kits come with a block off plate for the stock opening.
Old Jul 31, 2005 | 04:32 PM
94zLT1's Avatar
Re: Free Ram Air?
Oh i see 99...ram air sounds like bs to me in eveyones honest opionion do you think the front ram air opening coupled with the under radiator scoop "ram air mod" cut out would produce more gains than the "ram air mod" with the front blocked off? hmmm
i would think the first would be better (front and free ram air mod coupled)
Old Jul 31, 2005 | 05:40 PM
teke184's Avatar
Re: Free Ram Air?
since the "free ram air" mod isn't actually a ram air...
keeping the front opening and doing the FRA should get the best gains.
i don't think there is enough pressure built up with the FRA to warrent blocking off the front opening. as someone stated, the more open the air box is to outside air, the better off you are.
Old Jul 31, 2005 | 06:50 PM
99blackSS's Avatar
Re: Free Ram Air?
Good point, ram air wouldn't even occur on the FRA if ram air is even possible on cars. My personal conclusions:
FRA-not ram air no matter what, easier air flow (if you keep the filter clean ) and if your going to do that might as well raise the air box too.
Ram Air kits-CAI
